Farmall H brake cover
Lee
08-23-2003 21:59:48
I am rebuilding a farmall H and I lost the bolts that bolt the steel brake covers on. What size are they and how long thanks. I also lost transcover bolts how many and what are the different lengths. Thanks Lee
here, try this
08-24-2003 04:21:24
 Re: Farmall H brake cover in reply to Lee, 08-23-2003 21:59:48
well, seeing as you have the tractor there you can count holes and measure as well as anyone. the transmission cover bolts are 7/16. The original ones had a heavier head than the ones you will buy today. not sure on the caps for the brake cover. they are either 5/16 or 3/8. A good rule of thumb a cap screw will thead in about the depth of what 2 normal nuts for that size would be.
Lee
08-24-2003 05:52:56
 Re: Re: Farmall H brake cover in reply to here, try this, 08-24-2003 04:21:24
The tracter is 3 hours away from were I live I get to work on it about once a month . I am trying to save some time so I can buy them before I go home .
Nebraska Cowman
08-24-2003 11:02:31
 Re: Re: Re: Farmall H brake cover in reply to Lee, 08-24-2003 05:52:56
sorry. the parts book calls for 4- 7/16 x 1 3/4;
11- 7/16 x 3; and the brake cover gets 5- 3/8 x 3/4. All national coarse wit lock washers.
