Hydraulic Retrofit for Model A
Tim
08-24-2003 05:35:38
I have a '45 A and was wondering if anyone makes a hydraulic kit I can mount on the PTO.
Anyone know of current or former manufacturers of a kit?
Thanks in advace, Tim
BIG JOHN
08-24-2003 16:49:41
 Re: Hydraulic Retrofit for Model A in reply to Tim, 08-24-2003 05:35:38
Char-Lynn Hydraulics made one they called a "Power Pak". It is a complete unit all it one that attaches to either the PTO or the Belt Pully shaft. An excelent unit for what you want.
There is one listed on E-Bay right now. Don't see them listed very often. E-Bay Item #2553277099. It would be worth at least three times what the price is now, to you.
The person listing it must not know much about it because an "M" has a totally different "belly hydraulic pump". Don't let his description through you off.
GOOD LUCK
Ed Fisher
08-24-2003 06:16:19
Tim, I have a hydraulic system that I designed to fit my "A". It consists of a rectangular tank that mounts under the seat. The top of the tank is reinforced and has sealed threaded bolt holes that the hydraulic pump mounts to. The pump runs off the shaft that the belt pulley would mount on. This shaft turns faster than the PTO shaft wich provides faster hydraulic action. I have a hydraulic cylinder that mounts to the torque tube on the cultivator mounting boss behind the starter. This puts the lift/down pressure in the center of the tractor. The control valve mounted to the left fenter. I used this setup to lift/lower a woods mower deck but it is strong enough to handle almost anything that the "A" would be capable of. I now use a Super A and would sell the whole setup for $250. It will also work on a "BN".
