C wide front
Dale in Ar
08-24-2003 19:42:57
I am rebuilding a wide front for my Super C and need to replace the tie rod ends.The question,will the long tie rod from later models(666,766,886,and others)fit? I can find the short ends but not the long ends.Also,how much higher do they cost(I know they'll be costly) or should I just cut the ends and weld on cheeper tie rod ends?
David Bean
08-25-2003 10:20:57
 Re: C wide front in reply to Dale in Ar, 08-24-2003 19:42:57
Dale,
I'm in the same boat as you -- just mounted my new wide front end yesterday...once I had it on and figured out how things went together, I realized that a ball joint or two were bad and one of the tie rods was bent. It's a Super C front end as well.
If you happen to get your answer via email, would you mind posting it too? Thanks!
- David
Dale inAr
08-25-2003 20:01:01
 Re: Re: C wide front in reply to David Bean, 08-25-2003 10:20:57
I just priced the tie rod ends today from my I.H. parts dept.The short adjustable end was 25.00,now hold on to your drawers,the long tie rod that you adjust for wheel width,118.00 apiece.For those keeping score,that is 286.00 for tie rod ends on a Super"C" wide front,both ends.I think I'll cut and weld my long ends.
