how much can an M pull?
James Fisher
08-24-2003 19:48:28
I recently bought a Farmall M that has a super M engine. I would like to get a bigger bush hog and other implements. How big can I go? What about a plow?
Hugh MacKay
08-25-2003 03:28:46
 Re: how much can an M pull? in reply to James Fisher, 08-24-2003 19:48:28
James: I think there must be a lot of worn out 12' disks across America. Every time this subject comes up there are always a few people who can pull a 12' disk with an M.
A good cutting disk with 18" or 20" disk blades, 1-1/4 arbor bolts, 4-5" diameter solid steel spacers between disks. That will require 1 to 1-1/4 horse power per disk blade. Once the concave is worn off the disks they will not require much hp, nor will they be very effective. In fact I have seen people trying to use a worn out disk, and a land roller or packer would have been more effective.
Vern
08-24-2003 21:22:41
We used to pull 3-16s 8" deep in good loam soil.
earlschieb
08-24-2003 20:27:11
7 Foot bush hog, 3-14s on the plow size, 12 foot wheel disk.
Jimmy King
08-24-2003 21:30:21
 Re: Re: how much can an M pull? in reply to earlschieb, 08-24-2003 20:27:11
you can pull a 10 ft. bush hog for mowing pasture if in heavy brush 6ft. on any tractor
