H SERIALL PLATE NUMBERS DON'T MAKE SENSE
FARMIN RED
08-25-2003 11:02:54
I WAS LOOKING AT MY SERIAL PLATE FOR MY H AND IT IS A 1947 I KNOW THIS BECAUSE THE NUMBERS ARE IN THE 25,000 RANGE. THE THING THAT CONFUSES ME IS THAT I THOUGHT THAT THE MAX ENGINE RPM ON AN H WAS 1650. IT SAYS ON MY SERIAL TAG MAX RPM IS 1815. CAN ANYONE CLARIFY THIS FOR ME. THANKS
rustyfarmall
08-25-2003 13:26:26
 Re: H SERIALL PLATE NUMBERS DON'T MAKE SENSE in reply to FARMIN RED, 08-25-2003 11:02:54
I have 3 Hs and an I-4, they are all rated at 1815 rpm. they range in age from 1940-1950.
49 Cubber!
08-25-2003 12:39:08
Did you leave out a zero in your number?if its in the 25000 range it would be a 1940.
Randy in NE
08-25-2003 12:22:27
The tune up sheet for my '50 C has the following settings. High Idle (no load) Engine RPM/PTO RPM 1815/593. Rated Load Speed Engine RPM/PTO RPM 1650/539. This should be the same definitions as the H. The serial number tag has 1815 stamped on it. That is the only number that you can still make out.
