51 farmall gas m
rb
08-25-2003 11:52:38
have a 51 farmalll when enging is off amp meter all the wasoy to discharge side...cannot find a short, when running shows aprrox 7.5 vlts. could it be the regulator is stuck?
rb
08-27-2003 12:38:28
 Re: 51 farmall gas m in reply to rb, 08-25-2003 11:52:38
thanks , you both were 100 percent right
Fred
08-25-2003 18:57:21
I had the exact same problem in my 8n. As Bob M says, replace the regulator.
Bob M
08-25-2003 12:48:22
Sounds like a stuck regulator alright! Try disconnecting the wire to the "GEN" terminal at the regulator. If the ammeter returns to 0 it means the cutout relay inside the regulator has stuck closed. Best fix is to simply replace the regulator.
