''A'' PULLING POWER
PETE
08-26-2003 06:28:09
I AM USING MY 1940 ''A'' TO PULL A 5 FT. DISC.
WHEN THE DISC IS SET TO CUT THE DEEPEST POSSIBLE I HAVE BEEN IN 2ND GEAR . IT PULLS BUT IS UNDER
A PRETTY GOOD LOAD. AM I DOING DAMAGE EVEN IF THE
THE TRACTOR DOES'T HESITATE
CNKS
08-26-2003 20:04:28
 Re: ''A'' PULLING POWER in reply to PETE, 08-26-2003 06:28:09
Your tractor will develop engine wear, dpending on the load, it will last longer running around all day pulling nothing than it will pulling your disk. That said, it won't hurt anything if it is running the rated rpm. In the absence of a tach, if it builds up to speed rapidly, you aren't hurting anything. If it builds up very slowly, straining all the way, the valves will go first, then the rings, then---.
JB
08-26-2003 18:38:06
My Dad, pulled a set of 6' IH C?? disks from 1945 till 1949 with his A. In 1949 he upgraded to C and then in 1952 to SC. Our farm has hills and medium soil.
So your A should do the job.
JB
Hugh MacKay
08-26-2003 17:47:19
Pete: I wouldn't worry about the A unless it is over heating. Those little tractors will loose traction before you will hurt them. The C, SC, 200, etc are a different story, same power train as the offsets, but just a whole lot more tire.
Dave BN
08-26-2003 17:45:33
Your A should pull a 5ft disk. You should be able to work this tractor pretty hard if it's in good shape and has good fluids. Have you checked/changed your transmission fluid lately? What about the final drive fluid? Both are fairly easy and inexpensive to change and would make a big difference in wear in hard use. Dave.
mbnok
08-26-2003 16:57:47
An A in decent shape should pull a 5 foot disc. If it doesn't overheat keep on discing. If it overheats back off on angle, gear down , 1st is a little slow for good discing.
rustyfarmall
08-26-2003 06:45:46
Your tractor will have a shortened life doing it that way, use a lower gear, or get a smaller disc.
steveormary
08-27-2003 03:59:32
 Re: Re: ''A'' PULLING POWER in reply to rustyfarmall, 08-26-2003 06:45:46
Yeah,watch your heat gauge and oil pressure guage. If it starts to get hot oil pressure drops considerably you are probably working it too hard.
