farmall B-oil pressure
Jim Johnston
08-26-2003 16:04:30
My Farmall B When it first starts up the Oil pressure is a little less that half.After about 1.5hrs of mowing grass it drops so low that only a little white shows on the gauge.I am using sae #30.Is this normal?Can it be ajusted? My manual does not say much about this.I am concerned.Other tana that it is a great running B.Thanks for your help.
Dave BN
08-26-2003 17:50:46
 Re: farmall B-oil pressure in reply to Jim Johnston, 08-26-2003 16:04:30
Yes, replace or resurface the bottom plate on your oil pump. Also clean the screen, You can easily remove the screen to work on it. I bought a new relief spring a month ago from my Case/IH dealer for $5. The bottom plate was $80. I have good oil pressur now. Dave BN.
Dave_Id
08-26-2003 17:37:49
This is a very normal condition for these old C113's. You can drop the pan, and pull the pump and sand the cover casting down until it's flat again, I'm sure it's worn.. If you have a surface grinder, you can take a depth mic, and grind the housing down til you have about .005" clearance to the gear.
Another problem is the spring for the relief. I'm sure that ain't to the correct length anymore, and the last time I tried to get one from IH, they no longer stocked them, but if you are lucky, your dealer has one laying around yet.
