Reocuring Steering gear leak on 1466
Yellott Canby
08-26-2003 18:26:27
Hello, I have just pulled the steering wheel assembly out of my 1466 for the second time in about 10 engine hours. I can see that once again the big sleeve like rubber seal has failed on the steering gear "motor". The seal is about 3 inches in diameter and is about 4" tall. This time I can see it has been pushed up and out of the metal collar it fits under, I suppose by hydraulic pressure. I just replaced this seal about 10 hrs ago. That one had become stiff and unpliable. That one was only about 4 years and 40 engine hours old. Anyone know what might be making these fail? Could the steering mechanism be worn? Perhaps a relief valve is not opening somewhere. Thanks for any thoughts you might have. YC
RAS
08-27-2003 12:05:15
 Re: Reocuring Steering gear leak on 1466 in reply to Yellott Canby, 08-26-2003 18:26:27
We have no luck installing seals in the hand pump. There should be just leak off oil at that seal it is a low pressue seal. Sorry to say the only way we repair them is to replace the hand pump.
