farmall super m hyd won't lift brushhog
mark
08-27-2003 11:53:23
52 model super m - lift is fast and works up and down but will not lift weight or hold itself up
thanks
Wayne Swenson
08-27-2003 19:44:36
 Re: farmall super m hyd won't lift brushhog in reply to mark, 08-27-2003 11:53:23
Are you using 30 weight non-detergent oil?
That is what the pump was designed for when new.
Aces
08-27-2003 13:37:54
Mark If it is the belly pump and it will not hold load the ball seats would be bad, as far as lift could be relief valve or pump may need rebuild.
