International 444 diesel starter problems
David Cole
08-27-2003 13:04:24
Starter went out suddenly while working in hay. I have refirbished selonid. Starter seems to work fine, bench tested ok at a local auto parts store. However, when I put it on tractor it will not engage far enough to turn the flywheel.
Is there something else I need to check?
David
08-27-2003 16:10:51
 Re: International 444 diesel starter problems in reply to David Cole, 08-27-2003 13:04:24
What does the flywheel look like? My 444 diesel has a delco remy starter. Y ou may wantt o take the starter apart and make sure the shift lever (connects to the solenoid) is connected to the drive gear properly. The shift lever has 2 "tabs" that fit into a grove on the drive gear. if it has jumped out it won't push the drive gear into the flywheel. The "tabs" may have worn out on the shift lever.
