Starting M
Randy
08-28-2003 17:29:36
I bought a '51 M that had not been used for a while. I got it running a few days ago and now there is no fire past the distributor cap. Could this be a condensor problem? The tractor has been converted to 12 volt. Also is there an electronic ignition kit for Farmalls? Any help is appreciated.
Pawnee
08-29-2003 05:22:21
 Re: Starting M in reply to Randy, 08-28-2003 17:29:36
Yes they make an electronic ignition for the Farmalls. Search for Genesee on the web. Around $100. I don't have one yet but have only heard good things on this forum. Good luck!!
Nebraska Cowman
08-28-2003 17:52:39
fire past the dist cap? Do you mean it is getting fire to the cap? Pull coil wire out of cap and place it near the engine. open points with a screwdriver with out grounding them or crank the motor over and see if the spark jumps. If you have fire there the cap, wires, or plugs are bad.
