major gasket replacement, or not?
bill
08-28-2003 18:23:18
I am ready to replace the gasket between the lift all section and the tranny on my '40 H.
This looks like a MAJOR job. Is it? Also, can you give advice on what jacks / supports I might need to do it?
Any other advice is very much appreciated.
Thanks,
bill
CNKS
08-28-2003 19:42:29
 Re: major gasket replacement, or not? in reply to bill, 08-28-2003 18:23:18
The post below is correct. Transmission and lift all seals can be replaced without splitting the tractor.
randy hall
08-28-2003 18:29:58
there is no gasket between the clutch housing and the transmission case.
bill
08-28-2003 19:44:07
 Re: Re: major gasket replacement, or not? in reply to randy hall, 08-28-2003 18:29:58
there isn't?
then why does it look like there is?
keep in mind, i'm a very new Farmall owner!
Haas
08-29-2003 05:31:26
 Re: Re: Re: major gasket replacement, or not? in reply to bill, 08-28-2003 19:44:07
As others said, no gasket at that location. Most likely your main drive shaft or the transmission counter shaft seals are bad. Both can be replaced from under the tractor without splitting it apart.
Tim
08-28-2003 22:09:36
Not trying to sound like a smart a$$, but you might spend a few dollars and get a ITT repair manual for your H. It will show you where the oil is coming from and show you how to build the tools to remove the lift-all. Well worth the money. If you are seeing oil between the clutch housing and the motor the most likley place is the lift-all gasket between the pump and oil tank, it could also be the rear main seal on the motor.
bill
08-29-2003 05:44:33
 Re: Re: Re: Re: major gasket replacement, or not? in reply to Tim, 08-28-2003 22:09:36
tim, what is an ITT manual? where can i get one?
CNKS
08-29-2003 09:07:44
 Re: Re: Re: Re: Re: major gasket replacement, or n in reply to bill, 08-29-2003 05:44:33
ITT manuals can be bought at some farm supply stores. If you want to buy authentic IH manuals, the best quality is from Binder Books.
Ben in KY
08-29-2003 08:15:56
They sell manuals on this site. Over at the left under shop for parts.
