1954 Super H hydraulic fluid level
Packard
08-28-2003 22:28:46
I need to know how to check the hydraulic fluid level on a 1954 Super H it has a reservoir under gas tank? What type of fluid I read somewhere to use motor oil is this correct? Thanks
randy hall
08-29-2003 07:09:17
 Re: 1954 Super H hydraulic fluid level in reply to Packard , 08-28-2003 22:28:46
use the same oil that you use in the engine, just like the book says. i have been farming with these tractors for thirtyone years and that is what i put in the hydraulic systems of these old tractors and have never had a problem. on your super h just fill it up until it is full.
CNKS
08-29-2003 09:02:33
 Re: Re: 1954 Super H hydraulic fluid level in reply to randy hall, 08-29-2003 07:09:17
Yes it will work, but the late 1953-1954 Super H's have live hydraulics, not the H, early Super H belly pump. These systems were designed for touch control fluid, which has been replaced with Hytran. (I first drove an H in 1950).
CNKS
08-29-2003 06:02:17
I suppose motor oil will work, but the recommended fluid is Hytran, from your Case-IH dealer, or other sources that meet the Hytran specs. Add until the fluid is viseible in the filler opening.
