Thinking about buying an M
Jon
08-30-2003 17:51:29
I went and looked at am M today with strait sheet,metal good belt pully,hydraulic pump,and good tires.The only thing wrong with it is that the radiator leeks.He is asking 1,000 dollars for it is it a good deal? any advice is appreciated.
Nebraska Cowman
08-31-2003 05:52:55
 Re: Thinking about buying an M in reply to Jon, 08-30-2003 17:51:29
grab it in a heartbeat. Shop around, you should be able to get a new radiater for around $300, maybe a little less.
Don LC
08-30-2003 21:55:55
Sounds like you found yourself a good M ..... they are one of the best,most sought after of all the Farmall tractors....I wouldn't let it pass....$1000 is a very good price.....I have a '51..... .you did say the only thing you could find wrong is a leaky radiator!!!!A little hard to change out but worth it----put on a new one..... ..
Dave_Id
08-30-2003 18:58:03
The price seems okay, but the main thing to consider are the rear tires, you can easily spend $500 on tubes and tires, and if the rims are shot, there is another expense.
Jon
08-31-2003 05:32:58
 Re: Re: Thinking about buying an M in reply to Dave_Id, 08-30-2003 18:58:03
Both rear tires have 90 to 95 percent rubber with little weathering one rim is brand new and the other is in great shape.
Don LC
08-31-2003 15:37:28
 Re: Re: Re: Thinking about buying an M in reply to Jon, 08-31-2003 05:32:58
Where is it at I'll take it..... .
