Lug Nuts?? on rear of Super A
Super A Man
08-30-2003 20:17:42
Where is a good source to get the nuts that hold on the rear cultivator bars, 3 point hitch arms (a conversion on mine), and I guess the drawbar (I'm looking for one of them, too) on a Super A. Actually I guess they would hold on anything mounted to the rear of the tractor. I'm guessing that you would call them lug nuts, based on their shape (tapered on on side) even though they don't hold wheels. They are fine thread, and 1 1/4" hex. One of the studs is also missing, they are coarse thread on the side that goes into the tractor and fine on the nut side. I'm sure this hardware isn't too hard to find, but I thought I'd ask around on here before setting out on my journey. Thanks for any help.
Kevin
Hugh MacKay
08-31-2003 19:05:14
 Re: Lug Nuts?? on rear of Super A in reply to Super A Man, 08-30-2003 20:17:42
Super A Man: Truck wheel studs for cast spoke truck wheels will work. They are coarse thread both ends, but are about 10% of the cost.
VAJerry
08-31-2003 08:55:48
Dealer has them only place I could find them. Take your checkbook last I bought were $9 each for the nut only. I thought if you are or know a machinist you could turn a tapered "washer" to use with a bolt. But I have not persued this yet.
