injector pump400
Max Adams
08-30-2003 20:45:53
ok guys you all were a big help on the 2 row mounted picker question and a big thanks for that.
now for another one.i just acquired a 400 deisel,
and fuel is leaking between the pump and where it mounts..so i am guessing that the seal is bad,it is also filling the crank case.
what i need to know is,what type of pump is on the engine? it is stamped IH.i'm not too familar
with this one.i appreciate all the help. thanks in advance,max
Jimmy King
08-30-2003 21:33:04
 Re: injector pump400 in reply to Max Adams, 08-30-2003 20:45:53
This is an IH pump if you have a service manual it sould have a break down on it you can do anything you need to except run it on a test stand. We had a 400D it probably has a 450 kit in it if it has been overhauled. Had 15.5x38 on back it would hold its own on a 7ft. Roam offset plow, and burn about 2 gal per hr on it.
