450 Hydraulic pump?
Al
09-01-2003 06:31:18
Just got a Farmall 450 home. Looks like a nice one, only problem I see is there is a leak of hyd. fluid coming from around the fitting where the tach. cable is attached to the base of the distributor. It is hydraulic fluid. Can I just replace the seal on the hyd. pump or do I need to start looking for another pump? Don't have my parts book or owners manual yet. Also, I have a live pump to put on a Super M, converting the old belly pump to live hydraulics. Will that pump interchange with a 450? It's an IH pump.
Thanks,
Al
randy hall
09-01-2003 07:13:53
 Re: 450 Hydraulic pump? in reply to Al, 09-01-2003 06:31:18
you could install new seals or use the other pump.there are two different pumps so for parts you need the numbers from the pump because international purchased these pumps from pesco and cessna.
