Cultivator and Planter B Farmall
James Smith
09-01-2003 06:39:51
I have a B Farmall cultivator that I can not figure out how it mounts from the back. Another piece of equipment for the B Farmall is a PLANTER I need information on how to Mount and operate. Any help you can give me would be greatly appreciated. Thanks Jim Pictures would help.
Dave BN
09-01-2003 09:31:48
 Re: Cultivator and Planter B Farmall in reply to James Smith, 09-01-2003 06:39:51
Jim, you must remove both drawbars when you mount the cultivators. The round rod(rock shaft) runs along behind the seat and the big braces bolt to where the rear drawbar was. The smaller braces bolt to one of the fender bolts on the left side and to the seat bracket on the right side. There should be two triangle shapped brackets the bolt to the axil housings near the transmission. The rear center gang attaches to these triangles with a horizontal rod. Do you have hand lift or lift all? The rest of the story depends on which lift you have. Hope this helps. If you need more info e-mail me as I don't always have time to check this board. Don't know about the mounted planter. Dave.
