INTERNATIONAL H
ROGER
09-01-2003 10:14:20
I NEED TO FIND OUT HOW TO ADJUST FAN BELT ON MY H
Rick(MN)
09-01-2003 20:09:54
 Re: INTERNATIONAL H in reply to ROGER, 09-01-2003 10:14:20
Dave is right on the money here....the only thing I would add is that you might want to spray some of your favoite penetrant in the slots a few days before trying to adjust it. Hope this helps, Rick
Dave_Id
09-01-2003 11:12:40
The upper pulley is a two piece pulley that is threaded. Loosen the lock nut, and loosen the square headed screw if still original. Screw in the outer pulley, you may have to use a brass punch and hammer to get her moving, don't smack too hard, cuz they break fairly easy (I know), then line up one of the slots with the setscrew and thread it back in, and tighten lock nut.
