small farmall serial numbers
SHELDON STEWART
09-01-2003 14:41:33
I HAVE A SMALL FARMALL , IF YOU WHERE SITTING ON TRACTOR ON LEFT OF TRANS 351636 R2 L2X ON RIGHT OF TRANS 360719 R1 SAME SIDE METAL PLATE UP FRONT WAS 187213 UP UNDER THAT IS 1800 DOES ANYONE KNOW WHAT THIS IS AND HOW MUCH HORSE POWER IT HAS
Dave Bn
09-01-2003 16:28:18
 Re: small farmall serial numbers in reply to SHELDON STEWART, 09-01-2003 14:41:33
What color is your tractor? Do you sit in the middle of the tractor or off to the right side. Are there any letters before the numbers, like FAA or FAB. Not sure with only the info you gave. Dave.
SHELDON STEWART
09-01-2003 17:51:28
 Re: Re: small farmall serial numbers in reply to Dave Bn, 09-01-2003 16:28:18
THE TRACTOR IS RED ,AND YOU SIT TO THE RIGHT IT DOES NOT HAVE THE STYLE LINE LIKE THE BIGGER FARMALLS HAVE THAT RUN FROM GRILL TO BACK OF GAS TANK . THE GAS TANK SLOPES DOWN TO THE FLOOR . I WILL HAVE TO LOOK IN THE MORNING FOR ANY LETTERS . THANKS
Slowpoke
09-03-2003 00:54:51
 Re: Re: Re: small farmall serial numbers in reply to SHELDON STEWART, 09-01-2003 17:51:28
Could be s '47 A, '55 Cub or a '64 Cub Lowboy.
Most likely the Lowboy.
Remove Z for email.
