IH 2500B Trans.Problem
Mike Groom
09-01-2003 17:42:38
My 2500B has a syncromesh trans.with a fwd.-reverse shuttle lever,(not hydrostatic).The tellite on the dash came on and I have no fwd or reverse movement.The fluid level is fine and the filter is clean.New clutch and pressure plate.Any Ideas? Thanks,MG.
RAS
09-02-2003 21:07:33
 Re: IH 2500B Trans.Problem in reply to Mike Groom, 09-01-2003 17:42:38
The on the bottom of the trans you should find a valve. Remove the nut to remove the regulating valve & you might find the spring broken. You can get a kit to repair. This trans is the same as the T.A. trans without the sprag clutch. (one way bearing)
