560 dsl. head
Michael
09-01-2003 19:53:57
Will a d-282 head bolt onto a c-263 block, if so how much trouble would it be to do it.
Brian in MO
09-01-2003 20:15:52
 Re: 560 dsl. head in reply to Michael, 09-01-2003 19:53:57
I beleive the blocks are the same so yes.If your thinking of converting one I'm not sure what you will get into. The crank is the same, the rods are the same except the wristpin size is different (gas is alot smaller),the pistons are obviously different,the timing gears are all different, don't know about the cam for sure the timing cover is all different. You do have my curiousity up???? Brian
