IH No. 100 Mower - broken shaft
crockofbc
09-02-2003 06:28:58
About 30 years ago my Dad bought a used No. 100 balanced head Fast Hitch sickle mower. It mowed about 60 acres yearly for the first 15 years and quite a bit less the last 15. A couple days ago the wobble shaft sheared off at the belt pulley. We haven't checked out current availability and price yet but in the 1997 Case IH price book the price for the shaft kit (which includes shaft, bearings and a nut) was $750. This doesn't look like the simplest thing to replace either. Our first thought is that it's time to retire this mower. Any body ever have this happen or replaced a wobble shaft? Do any used parts exist out there? We would really appreciate any thoughts.
Heath
09-02-2003 19:14:13
 Re: IH No. 100 Mower - broken shaft in reply to crockofbc, 09-02-2003 06:28:58
A 990 mower conditioner has the same shaft. The case and yoke inside is different because the belt is on the other side. Sometimes you can get a junked 990 cheap. An IH balance head mower is the best mower ever made in my opinion. The New Holland is all right but it is very hard to change the sickle.
Brian in MO
09-02-2003 17:20:09
We broke 1 about a year ago found used parts (they were not cheap) and when we were going to put it together the used parts wasn't much better than what we had. Ended up buying a used New Holland at a local dealership in excellent shape very resonable compared to rebuilding the old one. Brian
jocco
09-02-2003 11:41:03
may be more effective to buy another mower and use one to make 2 today the new holland 451 and john deere 350 seem to be the thing also massey has one that is well liked in some parts of the country
Aces
09-02-2003 08:08:14
I have rebuilt these mowers some what deffecult the bearings have to be preloaded right. After the rebuid they must have a run in period, they should never be run over PTO speed and yes they are agood mower if run in properly and not run over PTO speed.
Al
09-02-2003 07:42:17
I have a 120 mower with wobble box and I paid $500. for it. I would keep the old one for parts and buy another. They are great mowers.
Evan350
09-02-2003 10:25:00
 Re: Re: IH No. 100 Mower - broken shaft in reply to Al, 09-02-2003 07:42:17
We previously had a #100 but the bearing in the 'wobble box' went bad and when two attempts to fix it failed, we bought the pictured #100 here for $450 about 2 years ago.
dave m
09-02-2003 17:22:24
 Re: Re: Re: IH No. 100 Mower - broken shaft in reply to Evan350, 09-02-2003 10:25:00
Evan where are you in ny send me an email I would like more imformation on that mower
