no fire from magneto
hillbilly
09-02-2003 07:59:47
need help. my h farmall has set for 5 or 6 years. it was running at that time. not getting any fire from magneto. can anyone tell me how to get to the points? does anyone have a good diagram of the magneto?
26Red
03-10-2009 10:40:01
 Re: Farmall 300 IPTO help, PLEASE in reply to scott6143, 03-09-2009 22:54:16
I changed the same gear on my 300...the splines on the other end of the shaft were twisted!
Have fun on the tear down..
Vern
09-02-2003 21:36:25
 Re: no fire from magneto in reply to hillbilly , 09-02-2003 07:59:47
You get to the points by removing the plate under the rotor.
Pete
09-02-2003 14:10:43
Points are available thru an IHC dealer or Rice Equipment. Setting is .013". Check current points for corrision and file flat & regap. Check for moisture in the mag also and dry out. Often, a good cleaning helps lots. Is the implulse tripping? Might need cleaning too.
Good luck.
