Can't solve H miss
Dan G
09-02-2003 08:02:19
I can't seem to figure out why my H still has a miss. It has a very occasional miss at an idle but does most of the missing while under even the slightest of loads. I replaced the points condensor, dist cap, wires, plugs and rebuilt the carburetor. My next guess is the coil but I hate to keep throwing money at it with no results. Anyone have any ideas? How do you test a coil?
EZ
09-02-2003 14:17:13
 Re: Can't solve H miss in reply to Dan G, 09-02-2003 08:02:19
Just my 2 cents, but my little '49 Cub was missing and having problems with load etc...until finally after swapping out the poor non-metal core ignition wires, it ran great for about 30 min. and then the MAG COIL just gave up. No more spark, tried and checked everything. Today I wired in a 12V coil and ballast resister. Voila, spark about a mile long, and no more miss, and I mean none. I let it idle for at least 45 mins. and I tell you the sound was sweet. Sure picked up my mood too.
Pawnee
09-02-2003 13:39:03
Reset the valves first. It is quick and easy. Solved a pretty bad miss I had in my SM. Search the archives for the instructions and clearances provided by the experts here previously. I have only done it once so i don't trust myself leading you thru it.
Bigdog
09-02-2003 08:56:55
Run a compression check. You may have a sticking or burned valve.
rustyfarmall
09-02-2003 10:39:46
 Re: Re: Can't solve H miss in reply to Bigdog, 09-02-2003 08:56:55
I agree, that's the next place to look.
Ben in KY
09-02-2003 12:23:19
 Re: Re: Re: Can't solve H miss in reply to rustyfarmall, 09-02-2003 10:39:46
I agree, run a compression check. BTW where can one find an adapter to use an automotive type of compression gauge on the big fat tractor spark plug holes ? I checked at my local Napa dealer and the couldn't even order one. They can usually get me most wear parts and gaskets for my tractor too.
I guess I will make one by welding a nonfouler to the base of an old plug if I don't find one soon.
CNKS
09-02-2003 20:20:40
 Re: Re: Re: Re: Can't solve H miss in reply to Ben in KY, 09-02-2003 12:23:19
I bought mine at NAPA early this year, pulled it right off the shelf, came with adaptor.
Rick(MN)
09-02-2003 18:56:45
I have a compression tester made by Sun and it has both sizes of threads built into it. Never even thought that some might have been built without both sizes. I have no idea if they still make them though. Rick
dhermesc
09-02-2003 14:07:08
Kind of surprised that NAPA couldn't find one, the compression checker I have came with the adaptor, and it was an elcheapo model.
