Super C Questions on Carter Carb float setting and
Merl Estep
09-02-2003 12:59:59
What is the proper float setting for the Carter Carb on the Super C? Second, the mounting bolts on the left hand side of the fast hitch where the hydraulic cylinder assembly is attached the tractor body have broken off. For the hydraulic cylinder to do its job, a welding job is needed. What is the proper way to reattach the fast hitch mount to the body of the tractor. There are some screw grooves left in the body.
FC
09-02-2003 13:41:32
 Re: Super C Questions on Carter Carb float setting in reply to Merl Estep, 09-02-2003 12:59:59
Merl, I have the Carter on a C and set the float "level" when inverted or needle is closed. The official setting is 11/64 below upper body casting +-1/64. This is from the manual for the carb. Cannot help with your other problem though.
