Fast-hitch limit?
Darren in TN
09-02-2003 14:26:51
Can anyone out there tell me what would be the approx. weight limit for the Super A fast-hitch (that's called one-point fast-hitch, right?)
I was thinking about farmerizing some old equipment to adapt it to the fast-hitch on my SA...
thanks,
d
Hugh MacKay
09-02-2003 14:59:05
 Re: Fast-hitch limit? in reply to Darren in TN, 09-02-2003 14:26:51
Darren: The limit on you fast hitch on the SA will be in the 400 to 700 lb. range. The closer you can get the weight to tractor the better. I have an S tine cultivator that I fabricated 6' wide and 3 rows of tines which take it back 4.5' behind tractor. Tractor has no problem lifting it, however ocasionally I like to put items on top of it just for moving purposes. If the item is much over 50 lbs I have to place it up close to tractor. The cultivator itself probably weighs 400-500 lbs. On the other end I have a sprayer probably 750 lbs full of material. The load with the sprayer is set very close to tractor. Sometimes when lifting sprayer I have to reach back and give a tug with my arm. When I am spraying I have two check chains from cross bar of hitch to rockshaft between fenders. I don't like spraying with all that weight on hydraulics.
Darren in TN
09-02-2003 18:05:11
 Re: Re: Fast-hitch limit? in reply to Hugh MacKay, 09-02-2003 14:59:05
Thanks, Hugh. As usual, you deliver the goods.
It sounds like I may be ok then-- the current project is an old Minneapolis Moline sickle mower. It's a little less than 400# by my guesstimation, and would you believe that the shaft is offset just right for my SA?
Thanks again,
d
