Help with w6
darind in WA
09-02-2003 21:27:43
Hello all you tractor buffs out there: I have a McCormic 1947 w6 that I would like to get running,but that is all I know about it, where can I find info on engine,tranny,pto,hp,etc. also I would like to add hydraulics for 3pt,and blade for snow,what size pump do I get. (Can you tell, first tractor) Thank you darind
BIG JOHN
09-03-2003 15:31:03
 Re: Help with w6 in reply to darind in WA, 09-02-2003 21:27:43
I think that you should rethink trying to add a 3 point hitch to this tractor. Hydraulics is not a problem, there are several options. The 3 point hitch is the PROBLEM.
This tractor was designed as a pulling tractor, ie. plows, disc's, etc. The operators seat is located back of the rear axel where the 3 point hitch would have to be attached. This would put you right in the middle of the hitch, not a real safe place to be. Also the tractor is mounted from the rear which would be a pain with a 3 point hitch to climb over. You would probably have to remove the fenders and the platform back of the rear axel.
Trail or drag type blades are available, which in the long run be a cheaper arangement for you. Wouldn't be as easy to back up with as a 3 point and you wouldn't be able to push with it, only pull.
GOOD LUCK
rustyfarmall
09-03-2003 04:46:10
The W-6 uses the same engine as the Farmall M, you need to be more specific as to why the tractor is not running now, and then the good people on this board will be better able to help.
The first thing you need to do is get the manuals for this tractor, operator, service, and parts manuals. Good luck, and have fun.
