Order Farmall Cub Parts Online
Hauling a Cub
Mark R
09-03-2003 12:48:35
I have a question about hauling a farmall Cub.
Can you haul a cub on a single axle 8' trailer? I as of yet could not find the lbs rating on my trailer but I'm still looking. Can you just drive it right on or do you have to take off wheels or anything like that to make it fit lengthwise. widthwise I assume is 4'. Will that work?
Secondly roughly how heavy do you think a cub with a front plow blade and mower is. Total weight. I've seen some people say a cub weights 1500lbs and others say 2500lbs.
Thanks for any help.
Bill B
09-04-2003 03:52:09
 Re: Hauling a Cub in reply to Mark R, 09-03-2003 12:48:35
Check the tires of your trailer to see if they are rated at sufficient capacity. I weighed my cub for the tractor pull at the fair last friday, and it was about 2100 pounds with wheel weights, and no implements. Make sure you have about 100 pounds of tongue weight on the hitch when the tractor is loaded, so the trailer will trail properly.
Kurt (mi)
09-04-2003 02:43:58
A cub will fit in the back of a 8' pickup bed. With the tailgate closed, you have to take the blade off though.
scotc
09-10-2003 20:47:39
 Re: Re: Hauling a Cub in reply to Kurt (mi), 09-04-2003 02:43:58
hey, i was gonna say that. May want a heavy 3/4 or a 1-ton though
BIG JOHN
09-03-2003 15:03:26
Your Cub will fit on the 8' trailer with room to spare. The International Harvester Tractor Data Book says, Weight: "1430 pounds (common field weight)" I doubt that this would include any wheel weights.
Don Barlar
09-03-2003 17:31:15
 Re: Re: Hauling a Cub in reply to BIG JOHN, 09-03-2003 15:03:26
I hauled my '48 Cub with belly mower attached in an '86 Ford long wheel base pickup (8 foot bed) and it fit perfectly with tailgate closed. I got it home, backed truck in a ditch, lowered tailgate and backed Cub out. Don
Okla/kans Bill
09-03-2003 14:54:56
yes you should be able too. I haul my 48 in the back of my pk with the wheel wells inside. It goes inbetween them perfectly
