Order Farmall Cub Parts Online
Cub ain't runnin right??
Scooby
09-03-2003 17:51:33
I am new to the Cub, and am in the process of tarin' into it. It doesn't want to run very good, at idle if you set the carb, o.k., but when you rev it up, or load it, it sputters out, and you need to choke about half, but if you set the carb at fast idle, then as soon as you idle back, she sputters out, and dies... any ideas...-Scoob
George Willer
09-04-2003 07:38:41
 Re: Cub ain't runnin right?? in reply to Scooby, 09-03-2003 17:51:33
Here's my idea...your high speed jet is plugged. An easy fix. You have adjusted the idle jet too rich to make up for it.
Time to do some carb work!
George Willer
