Cranky starting H
Jeff w/an H
09-04-2003 06:23:05
My tractor was running perfectly, but for the last two weeks it seems to flood the carb every time I try to start it. Then I wait 5 mins., try again, and she starts. What to do?
Tim Kincaid
09-06-2003 12:47:17
 Re: Cranky starting H in reply to Jeff w/an H, 09-04-2003 06:23:05
What have you looked at so far.. Check your plugs and and points. Tim K.
Jeff w/an H
09-07-2003 19:38:50
 Re: Re: Cranky starting H in reply to Tim Kincaid, 09-06-2003 12:47:17
Plugs are fine. How do you check the points? What to look for?
Tim Kincaid
09-08-2003 21:09:13
 Re: Re: Re: Cranky starting H in reply to Jeff w/an H, 09-07-2003 19:38:50
Remove coil wire from cap ,place it about a 1/4 inch from a good ground turn the switch on and slowly open the points with a screwdriver ,spark should be blue and very consistent as you open and close the points..
