Whats a good 60 horse tractor?
Kelly C
09-04-2003 12:26:29
Next year I may want to start some big bales.
My H and 300 can handle the small bale stuff just fine, but I think I may need a few more HP to get into big bales.
What do you guys think would be a good IH tractor to start looking at to bale and pick them up with?
Money is deffently an object of concern.
Jimmy King
09-06-2003 12:41:37
 Re: Whats a good 60 horse tractor? in reply to Kelly C, 09-04-2003 12:26:29
Kelly I am a day late on this post, but here goes anyway. I started round bales with a 605A Vemeer bought new. You do not want a compression roller baler as I have laid on my back and sweated blood cutting hay from roller. I have a 605F Vemeer now, the begining of the good Vemeer balers. It was recomended for 70HP I pull it with a 756D, but have pulled it with a 460D just slower was force to until had time to fix PTO on 756. I pulled the 605A with it all the time and a 574 gas. I hve pulled the 605F with a 544 gas it pulled it all right same as 460D, but did like gas while pulling it. If you could find good 504F vemeer or later model, a 560 should play with it. From what I saw him say once Hugh is about a year younger than I, and he seems to have a lot of commen since. A 300 would pull a 504F would be about like me pulling the 605F with my 460. Just my coments a day late and a dollar short.
Rick(MN)
09-05-2003 17:38:52
Never ceases to amaze me how easy it is for one man to spend another man's money. Take a chance on the 300, just be very careful about committing to hilly ground or taking on more than you can handle until you see how its gonna work for you. I'm only 30 miles or so away. So if ya get in a pinch, I'd come with the 450 or 560 and help you for a day or so. There are several models that would suit your purpose just fine. But in my opinion, the condition of the tractor is a much bigger factor than the model number. Congratulations on being conservative. Makes it a lot easier to keep the wife happy when you are able to turn a profit.
Andy Martin
09-05-2003 17:14:52
Kelly:
We've baled about 300 round bales with the M this year.
Pay attention to the guys talking about hills. We hay pretty gently rolling fields so hills aren't a problem. But with a good windrow coming up out of a steep bottom even first gear is not slow enough for the M. And I can't stop going down a steep hill with a full bale so if it is time to tie I have to pull out of the windrow and hit bottom to let out the bale.
You can vary the size of your windrow. We've been baling three nine foot cuts. Smaller windrow=less hp required. A 4x6 baler will take less hp than my 5x6 if it is an efficient baler. If it has it's own hydraulic pump, etc, it takes more hp.
Obviously I agree with Hugh that cheap can be the way to go, even if it is a little slower. It is a LOT cheaper. The pickup on my Vermeer 605 Super C came apart and the dealer put me on to a guy who had one for sale. He was a custom baler who had just quit using it in 1999 when he got a new baler. Bought it for $200. It is in better shape than the first baler I got for $1300. So now I have two sets of belts and almost a spare baler for $1500. Vermeer made the first large round baler, and this is an early model, so it is about like the M, new enough to have the bugs worked out but old enough to be simple, no electronics (or electrics!) and takes low HP.
A neighbor I trust told me to get rid of the 605C and get at least a 605K. Said it would not start a bale. It was too worn for that to be true. Somebody had figured out how to do it. I'm not there but am getting better and can make money the first year at $15/bale custom baling.
I'm not in an IH area so I don't know anything about IH round balers but from what I've seen I got real lucky buying the Vermeer.
Newer balers are faster, as is net wrap, but you have to have something else to do when you get done or it is a waste of money to go faster. Ever seen the guys with the big tractors sitting around the coffee shop because they got done early? I don't drink coffee.
Thanks Guys!!!---Kelly C
09-05-2003 15:25:22
Thanks for the imput so far guys. I still need to bone up on Round balers as I know nothing about them yet.
I plan on trying to use my 300 to start.
I do know of a 560 ( I think its a 560) That is not for sale yet but may be next year. With a loader and big bale attachments. The guy was thinking in the $3500 range. I dont think (even if I dont have the hay money) I could pass that one up if he sells it.
farmalljudy
09-05-2003 15:17:09
I've discussed the round baler issue with the JD dealer and also the NH dealer and they both recommended no smaller than 65hp for running a 4x6 baler, assuming you wind them up to maybe 5.5'. You can certainly use lesser tractors, and as others above have mentioned, for a few hundred bales it may not make that much difference, but sooner or later you'll have some repair bills because you're overloading your equipment. Maybe get buy with the 300 for a year, then look for a solid, if not semi-ugly 706 or 806, fix it up and bale away.
Super A Man
09-05-2003 07:39:14
I'll throw my two cents in for what it's worth. I don't have much personal experience to speak of, but a friend of mine uses a 70's Massey Ferguson 245 with a Hesston 560 round baler for 400-600 bales a year, no problems. I don't know what HP your 300 is but his MF is 40-45. Of course these are the smaller round bales.
FC
09-05-2003 07:11:27
I have been watching this discussion as I am interested in the same thing as Kelly. I have a few acres (roughly 50) that I would like to bale myself. I have once again proved that if you want something done do it yourself. I sold dads square baler, and am either going to purchase another, or buy a larger tractor and round baler. Like Kelly I wondered how big is big enough. I do not need or want a large horse tractor with the full dress of cab and ac to work a little over 100 acres. For the life of me I cannot see how some folks can economically run the big machines in this area on small acreages. I have a neighbor with a few hundred acres running a new FWA New Holland complete with cab and AC. Not sure of the price tag, but I would bet it will take a few head of cattle to pay for it. I believe I recently saw a post where Andy Martin was running an M with a round baler. I would like to purchase something like an M or 300, etc. with a loader and even if it is marginal I can take my time. I just will not look as good doing it (or will I?).
Kelly C
09-05-2003 12:05:27
 Re: Re: Whats a good 60 horse tractor? in reply to FC, 09-05-2003 07:11:27
The reason I am looking at this.
Horse guys/Gals want thier hay done in small squares. No problem There. I am gaining customers all the time doing this. The main thing here is its usually real crappy fields, havent been done in long time ect. Going shares is a crap shoot as the hay might suck. Buck a bale I will bale any thing you want.
cattle/dairy guys sure could use the help. esp with 2nd or 3rd cuttings as they are starting to get real busy with other things. The real busy part takes away any willingness to go small square bales. No time to mess with them things.
Thats where me being able to do some big uns comes in. As this is really just a hobby right now for me. I cant (wont) go big bucks on the equipment.
Now if I can get my 300 to make big uns for a year or 2 till I get a customer base and some cash.
( I buy hay stuff only with hay money)
That would be great.
more on this--Kelly C
09-05-2003 12:27:26
 Re: Re: Re: Whats a good 60 horse tractor? in reply to Kelly C, 09-05-2003 12:05:27
I have also run into a couple of guys that had great grass and wanted to go shares but wanted big bales. I would have loved to do 1/2 the field in big uns for him and then bale my 1/2 in small for the horse market.
FC
09-05-2003 12:57:28
 Re: Re: Re: Re: Whats a good 60 horse tractor? in reply to more on this--Kelly C, 09-05-2003 12:27:26
Kelly, I wish you were near me....I have approx. 60 acres going to waste because no one will bale on the shares. I have had a couple guys promise and never show up or call. The hay is not much on quality now, but there is still some good stuff in there. As I said I sold dads old square baler a few years ago thinking I would never go back to wanting to bale, but since I am now building a house on the land I am going to work it a little. Like you, I cannot afford the big gun tractor and baler, but can put a little more time in than some are willing to. I figure it would take a lot of hours to add up to the $$ difference especially on the acreage I have. I would like to find a NH square baler like you have and bale up a few to sell to the horse guys like you said....
to bad not by me-Kelly C
09-05-2003 13:38:27
 Re: Re: Re: Re: Re: Whats a good 60 horse tractor? in reply to FC, 09-05-2003 12:57:28
Too bad your not. There is a sale down the rd this saturday. They have a NH68 looks to be usable and 2 NH273's one with a thrower. This is deere country here so those NH's might go cheaper.
Never know for sure though these guys get kind of fickle at the sales.
Kelly C
09-05-2003 13:27:23
I cant do it any other way. I want to farm some.Cant afford what it takes to really do it.
Wife wont let me have cattle ( I would if I could).
So a haying I will go. There is always haying that needs to be done.
I wish I had more time right now. Early this year I was wondering about it. Now we have had a dry spell and every one needing hay is getting nevous. Gona hang onto my hay till spring. I bet I get $4 a bale then.
4020
09-05-2003 06:24:01
For round baling either the hydro or a 4020 powershift.
ckh
09-04-2003 20:43:10
Used to bale with a NH 850 round baler and IH 806.
It was a great combo however, I must say I would argee with Hugh (on using the 300) that baler didnt seem to need much in the way of HP. I would be game to give the 300 a try esp. if on flat or gentle rolling ground. You might want to look for a wide front tractor if trying to add to your collection and the 656,706,756, 806 are all good older tractors and as with anything just check em out.
John A
09-04-2003 20:16:12
Kelly, I agree with most of the post here tonight. (Bigger is Better) ! There is No substitute for horse power. With that said the 706/806 or 756/856 will fill the bill. If you are bent on a gas motor, go LP on one of these versions. They run clean, simple to work on. Later then put a loader on to move bales. If necessary you can load Semi's. 2 rows tall. The letter and number series with the smaller 56s will get close but not where you need it. I have a 966 open station with a 2350 IH loader, great combination. I seldom apon never, use a 3 pt bale fork now. Good luck,
John A.
PS... The only thing else you will need is a spinner knob on the steering wheel, And Airplane tires on the front end. Light years ahead and better than standard Ag front tires
Later.....
Dale
09-04-2003 17:38:09
We use a Case IH 695 and it does fine it was one of the last tractors with the IH 239 engine.Its the same tractor as the 674 684 and I think a 544 we had years ago had that engine also.
MASSEYHARRIS MAN
09-04-2003 17:20:25
the 55 massey harris. a 770 oliver if you go with a 806, get diesel.
the tractor vet
09-04-2003 17:12:00
You will find out that a late model 706 with either the 291 gasser or the 310 german or like one said a 806is far better , as we have in the circel that i farm in a that running the same baler with differnt tractor as we have the bale vary from tractor to tractor as we did have one 706 with the 263 gas and one with a 291 gas and the 291 made better bales then i got the 806 and with the added hp it did a lot better and held better on our hilly ground. then we or i should say that Eugene got the 1066 and that is the tractor we use now on the baler.
Nebraska Cowman
09-04-2003 16:31:13
I have to agree with Hugh on this one. I bale with a 855 new holland with either my 656 or 86 hydro. Ideal baler tractors if you ask me. The 656 is gear drive. fuel consumption is around 1 1/2 gal an hour. Try that big boys.
Hugh MacKay
09-04-2003 14:17:03
Kelly: There is only few choises 560, 656, 666 and 686. I have baled thousands of round bales with my 560 and 656. Sure they labour a bit at the end of the bale, but you know what, 1066 was no faster, just burnt more fuel. I have even rolled a few bales with the IH 241 round baler and 300 when other tractors were busy. I don't know what all the fuss is about on hp for a round baler. I will grant you 300 was not as fast as others but it was putting more hay up per hour than it would with square baler. That was the first 241 baler our dealer sold, so I was making round bales before some of you guys were born. If I only had a few hundred round bales per season, I wouldn't hesitate trying the 300.
TP from Central PA
09-04-2003 15:43:19
 Re: Re: Whats a good 60 horse tractor? in reply to Hugh MacKay, 09-04-2003 14:17:03
I wouldn't joke around even trying the 300 on a round baler..... ...That would just cause more wear and tear than it is worth. We use our neighbors Gehl round baler(Silage Special) and IH 186 Hydro. If I was doing even a minor amount of round bales I would find a 826 Hydro..... .....They may cost more to repair but are built for the hay field! Our hills here will really push a tractor around on a round baler, I'd go bigger rather than smaller..... ..... A good 706 Diesel would be just the ticket if you don't like the Hydro idea..... ....
Oh, if you want a real 60 hp tractor..... Get an M-TA(Grin ;-p)
Hugh MacKay
09-04-2003 16:11:54
 Re: Re: Re: Whats a good 60 horse tractor? in reply to TP from Central PA, 09-04-2003 15:43:19
Come on now, damn baler and bale wouldn't weigh more than couple of ton. I've hauled many a 5 ton load of silage to my barn with 300 in 3rd gear. You guys just think you need big horse power, just because you like to use big horse power. Sure I'll go with the big tractor if I were going to bale 3000-5000 round bales. Kelly is talking a few hundred. The first year in my farming career I plowed a hundred acres I did it with a Farmall 130 and 2 bottom fast hitch plow, and made money.
Kelly C
09-05-2003 12:55:43
 Re: Re: Re: Re: Whats a good 60 horse tractor? in reply to Hugh MacKay, 09-04-2003 16:11:54
Hugh!
I like your stuff. I wish you lived by me. I would be over to your place all the time sucking your brain dry.
Hugh MacKay
09-05-2003 14:01:46
 Re: Re: Re: Re: Re: Whats a good 60 horse tractor? in reply to Kelly C, 09-05-2003 12:55:43
Kelly: You don't live that far away, just on the other side of Lakes Huron and Michigan and States of Michigan and Wisconsin and to the south of Lake Superior.
When you started this thread you did say money was an item, and I do know where your coming from on that one. I said on another thread a few days back, if I go back over my finincial statments, I always made more money in the times I was under powered. When I think back to the years my dad and I milked 40 cows and baled 30,000 bales of hay per year with nothing more for power than Farmalls 300, 130 and Cockshutt 540. Then came silage and the years with 560D trying to do the job of an 806. Man those were the good years, always had a new car and pickup every 5 years.
No your not going to set the world on fire round baling with the 300, but you will get some hay rolled up. Roy made a good point, some of those round balers suck up a lot of power, while others seem to run very easy. That IH 241 I had was a 5x6 baler and I thought it turned very easy. I only made the bales 5' dameter as we were handling them with skidsteer loaders. Had the hay stored on floor 16" spaced floor joists and 2" flooring. With 6' bales those little loaders would break through between floor joists.
Doing it this way just gives you a bit more time to buy a larger tractor. If your like me you always pay too much when you buy quickly. Take your time on a used larger tractor, they are not going up in price. Little ones might but 60 to 100 hp aren't.
Kelly C
09-05-2003 14:38:52
 Re: Re: Re: Re: Re: Re: Whats a good 60 horse trac in reply to Hugh MacKay, 09-05-2003 14:01:46
I dont know a whole lot about it, but I did watch my Grandfather and what he did with his farm.
He only had 80 acres, with his WD 45 and a 53 ford running about 40 head of cattle. He made a proffit every year. Dont know how much he would never ever say.
But he watched all the neighbors get bigger and bigger and show up with all the bigger newer stuff to run it.
One day as the guy accross the road was having a new haybine delivered. My gramps looked at me and said " they are going to go broke". He then just walked into the house for dinner never said another word about it. In 1982 he was right the guy accross the street and a few more down the rd all had sales.
In 1983 Gramps got a great deal on 600 acres near by. He paid cash for the land.
He then found that his AC all crop 66 was to small for the work to be done. He found a used Massey Ferguson self propelled combine at a sale for $1000. He used that for 4 or 5 years. Then sold the combine for $2000. He then sold the land for a tiddy proffit. Dumped the cash into CD's wile interest was at 18% in those days. He locked it in for as long as he could and went back to farming his 80 acres.
Not sure of the exact years of this as I didnt really care what was going on at the time. I was to busy farting around. But I did catch some of what he was doing.
hugh MacKay
09-05-2003 16:17:40
 Re: Re: Re: Re: Re: Re: Re: Whats a good 60 horse in reply to Kelly C, 09-05-2003 14:38:52
Kelly: You may have been farting around but do remember your grand dad's formula though. My dad bought land in 1938 for $1.00 per acre. Now the experts say that can't happen again, governments won't let it happen. As I see it here in Canada anyway, if politicians keep buying our votes with our money, what happens when the tax rate gets to 115% of our gross earnings. Something will have to give. The very best advise one could give today is keep yourself financially healthy. Opertunities like your grand dad's or my dad's are what make fortunes. I have been waiting close to 15 years for it to happen, just wish the government would stop proping it up.
I know a couple of guys who lived through the thirties and took advantage of the times. They are just hopeing they live long enough for another kick at the can.
TP from Central PA
09-05-2003 03:54:53
In a pinch it would make sense, but even if Kelly decides now he is only going to make acouple hundred..... ..That could change in a year or two. It pays a whole lot better to get the good stuff in the beginning then do it half a$$ and end up having to do it all over again. Here you don't need power on a round baler, you need weight..... ....
Kelly C
09-04-2003 14:45:44
I dont think it would be any more than that for the 1st year or 2 any way. If I could find a round baler that my 300 could run that would be great!! I will be putting a 3pt on the 300 so a bale spear could work on that also.
rustyfarmall
09-04-2003 13:40:19
A 560 would handle it but might be marginal on horsepower. I think I would look for a 706 or better yet, an 806.
Ben in KY
09-04-2003 13:25:13
What do you mean by big bales ? Big round ones or big square ones ? The big square balers I have seen seem to take close to 100 HP.
Kelly C
09-04-2003 13:32:58
 Re: Re: Whats a good 60 horse tractor? in reply to Ben in KY, 09-04-2003 13:25:13
Round ones. Have to find a good used round baler too.
Roy in UK
09-04-2003 14:38:19
 Re: Re: Re: Whats a good 60 horse tractor? in reply to Kelly C, 09-04-2003 13:32:58
I tell you what Kelly, where power requirement is concerned round balers do vary! The variable chamber belt types seem easier to turn than the fixed chamber roller type. To give you an example, my JD 550 seemed to take a lot less power than the Claas Rollant 62 I had. My neighbour had a 75 hp Massey on his Claas 44 4' round baler and it used to work it to death.
