186 hydro
Eldon
09-04-2003 20:29:37
Is a 186 hydro open or closed center hydraulics? How do you tell? How about a 656?
David Saville
09-05-2003 19:57:16
 Re: 186 hydro in reply to Eldon, 09-04-2003 20:29:37
Early 186's had open centre late ones had closed. The parts book has the serial number break. I "think" if you have closed centre you will have flow rate control levers in the cab like an 88 series.
Heath
09-05-2003 18:55:22
A 186 is the same as the 656 but a 1981 186 is different.
Jim
09-05-2003 04:20:53
The hydraulics used for equipment are open center.
When you move control lever to raise or lower (without cylinder hooked up) and system goes on high pressure you have open center, if it doesn't, you have a closed system, if every thing is working ok.
