300 Utility with Davis Backhoe
Phil
09-05-2003 20:12:12
I have a 300 utility with a Davis Backhoe. One of the Outrigger legs has a blown hose. I cannot get a wrench down inside to remove the old hose and was wondering how I can get the whole leg to slide out of the tube. Is this possible? Does anyone have any experience with one of these.
Thanks,
Phil
Jailkeeper
09-05-2003 21:22:26
 Re: 300 Utility with Davis Backhoe in reply to Phil, 09-05-2003 20:12:12
I'm just guessing, because I don't know how your outrigger is built, but you could probably take the pin out that holds the leg and cylinder inside the tube. That should let everything come down so you can get to the fitting.
Phil
09-06-2003 06:33:21
 Re: Re: 300 Utility with Davis Backhoe in reply to Jailkeeper, 09-05-2003 21:22:26
Thanks for the suggestion. I tried that, but there are two metal pieces that are welded inside the tube at the bottom to beef up the shoe mounting holes. The cylinder stops on top of them. I was trying to get the whole leg to slide out of the tube, but it does not seem to want to move.
Thanks,
Phil
