summer project
speed bump
09-05-2003 21:14:03
third party image
Here is a picture of my summer project. The rig is mounted on my '48 Farmall H Wide Front. The hydraulic cylinder is borrowed from my Saginaw 3-point hitch. The black angle iron pieces are connected to the rear axle brackets. Now all I need is some snow!
RustyFarmall
09-06-2003 05:58:37
 Re: summer project in reply to speed bump, 09-05-2003 21:14:03
I will compliment you on your work, it looks very good, but I think you will find that you built it just a little bit on the light duty side. If you hit anything solid with the blade, I think those black angle irons are going to just bend. Please don't think that I am just trying to be negative, and I am not trying to be offensive, but an H can push a lot harder than what you think.
speed bump
09-06-2003 20:34:36
 Re: Re: summer project in reply to RustyFarmall, 09-06-2003 05:58:37
I know it wasn't visible in the picture, but the black pieces are 3/8" thick, 2" angle iron, a little less than 9' long. There is a cross member (about 20" long) made of u-channel about half-way. Thanks for the head's up...I'll just keep an eye on them and reinforce if necessary.
Jailkeeper
09-05-2003 21:19:08
Looks good Speed Bump. Are you gonna hire out for custom plowing? Better get a heat houser on that H if you do!!!
williamf
09-06-2003 01:58:53
 Re: Re: summer project in reply to Jailkeeper, 09-05-2003 21:19:08
I haven't got my glasses with me - I can't quite make out the model number on that green one in the background. It's a 4020, right?
Wm ;-)
speed bump
09-06-2003 05:29:56
 Re: Re: Re: summer project in reply to williamf, 09-06-2003 01:58:53
actually, it's a 5520. (i wish) ;o)
Gordon/Ia
09-05-2003 22:00:59
Looks good. Should handle nicely.
Wish my shop floor looked that nice and clean.
Jailkeeper
09-05-2003 22:19:40
 Re: Re: Re: summer project in reply to Gordon/Ia, 09-05-2003 22:00:59
He probably just cleaned up for the picture! (wink)
I wish my shop had a concrete floor.
haymeadow52
09-06-2003 00:05:53
 Re: Re: Re: Re: summer project in reply to Jailkeeper, 09-05-2003 22:19:40
I wish I had a shop.
Jacques
09-06-2003 18:07:53
 Re: Re: Re: Re: Re: summer project in reply to haymeadow52, 09-06-2003 00:05:53
So that's what concrete looks like!
Nice lookin' outfit you built there!
