IH 600 diesel hydraulic pump
MD Karl
09-06-2003 22:10:35
The hydraulic pump on my brother's 600 diesel has a bad seal and dumped all of the hydraulic fluid into the crankcase. We need either a seal and gasket kit for it or a new (if they have them) or good used replacement. We had a hydraulic pump go bad on our farmall 300 and the local CaseIH dealer highly discouraged getting a seal and gasket kit. I'm not even sure that you could get the kit. Any help is appreciated. He has the Thompson style pump on his tractor. Thanks for any help.
Jim
09-07-2003 10:15:48
 Re: IH 600 diesel hydraulic pump in reply to MD Karl, 09-06-2003 22:10:35
If down time is not a problem, I,d take pump off disassemble, and check condition, if blown internal seal and the housing is not hurt, why not try a repair. If housing has a oilcuts in it save your money and try for a new or remaned.
justin
09-07-2003 06:33:45
I have a NOS pump available if you decide to replace the pump. Email for more info
Jimmy King
09-06-2003 23:50:41
If you can find a seal and gasket set and not to high you don't have much to lose the first time if it works you are ahead if it doesn't then go the pump route.
