adding power steering
jake
09-08-2003 10:37:05
After purchasing a 400d with a cornpicker, dad thinks he needs power steering. A neighbor has a few parts left on a junked 400 gas. He says we can have everything we need for the power steering for $100.00. What all do we need? Is this a good price? It is a behlen unit I believe. This is just an assumption but it is much larger than a char-lynn. By the way, dads 400 only has 2 remotes but no fast hitch. Thanks for all you help jake.
Jimmy King
09-08-2003 14:07:54
 Re: adding power steering in reply to jake, 09-08-2003 10:37:05
We put a behlen unit on a 400D years ago if I remember right we had to change the bend in the air cleaner pipe just a little. don't expect it to work like hydrostaic does or even like it did on a gas model because of hte weight differenceof the engine on the Diesel, but it is still a big help. $100 is cheep
Aces
09-08-2003 13:52:45
Jake the power steering was a behlen, it used a flow devider valve to sent 2 / 3 galons to the power steering unit so you will need the flow devider off his 400 his front steering shaft or cut yours and put key way in it hoses from the low devider. Some braces for the behlen. Hope this helps some
Bob in SE Nebraska
09-08-2003 13:52:18
That sounds like an excellent deal to me. I will be happy to send pictures of how my power steering was added to my 400. E-mail me if you need the pictures.
Bob
