W-4 motor removal.
Bob Quale
09-08-2003 14:27:15
In order to unbolt the motor from the back part of the frame, it lookes like I have to remove the casting under the fuel tank, the one that holdes the starter and side flywheel. Does that sound right? Are there lots of parts under there I should be carefull with?
Thanks Bob
49 Cubber!
09-08-2003 18:01:53
 Re: W-4 motor removal. in reply to Bob Quale, 09-08-2003 14:27:15
Your right about removing the casting,you have to get to the clutch in oreder to get it out.If you can,take pics of it while your removing it.It will help to have them when you put it back in,which is fairly easy.Dont put the motor monuting bolts back in until you have the cluch assemblt completely back together as you will have to tilt the engine to get some parts back in right.(I think!!!!! Its been some time since I had restored my -4
