Smoke from oil breather..
Stan(PA)
09-08-2003 17:27:17
I notice some smoke from the oil breather when my '46 A is under load. It only happens when the mower hits higher grass, with low grass or mower disengaged there is no smoke. Is this "normal", or are the rings going bad? ...Stan
Doug in OR
09-08-2003 18:43:43
 Re: Smoke from oil breather.. in reply to Stan(PA), 09-08-2003 17:27:17
Probably rings. You'll get more blow-by when you put the engine under a load - resulting in more gasses passing by the rings.
