Super M Head Cracks
Jerry B
09-08-2003 17:34:44
I am rebuilding my 1952 SM, found that the cylinder head, casting number 8060, is shot, multiple cracks. Contacted a parts place and was told they had 5 SM heads, all cracked.
The guy told me he had M heads which would bolt right up, numbers 8777,8790,6336 and 8574, the only one I could find was the 8574 and that looks like it was for an LP engine, was told I would lose a little compression, never miss it.
Does anyone have any information on these other heads or where I might find the correct one and is this a common problem for SM heads?
Thanks
Jim
09-09-2003 07:50:51
 Re: Super M Head Cracks in reply to Jerry B, 09-08-2003 17:34:44
The 8574 head was the replacement for the 8060. I have found that the 8574 head is less likely to crack of all of the M heads.
Jim
09-09-2003 07:43:10
I have a 8574 head magnafluxed with no cracks, new seats, new valve guides & valves reground. Located in eastern Iowa. Contact me if you might be interested. (563)583-3716.
Duner Wi
09-09-2003 05:17:44
I have what the IH dealer called a recast head on my gas M for about 20 years. Keep anti freeze in it all year and have not had problems yet. Valve guides had shrunk due to the heat and needed to be reamed . I had the head magnifluxed and it shows cracks but it works fine.
rustyfarmall
09-09-2003 04:38:55
Where are the cracks? and how bad? was the head leaking before you tore it down? As you said, you cannot find one that doesn't have cracks in it. Maybe the head you have won't give you any trouble, just the way it is.
Charlie
09-08-2003 20:10:24
Jerry, I don't know about M's. Last winter I went to do a head job on my H, it was cracked. I had a spare head in the garage and when we looked, it was cracked too. The local IH mechanic told me most of the Farmall heads he went to rebuild were cracked and he has been doing it for years. I never heard of it either. I finally found a good head, but it cost.
randy hall
09-08-2003 18:20:18
i have a good 8060 head that i would sell email me at rhfarms@friendlynet.com
CNKS
09-08-2003 18:11:43
Call Mike at Steel Wheel Ranch -785-548-7437- He will have a rebuilt head, or a a good used one if you don't want the parts, and will know what he is talking about.
jakee
09-08-2003 17:38:42
the 8574 will work just fine and the cc,s in the head are about the same,i usally cut abouy .090 of them and have even cut as mutch as .190 of some for pulling
CNKS
09-08-2003 18:14:56
 Re: Re: Super M Head Cracks in reply to jakee, 09-08-2003 17:38:42
I posted before I read yours, no offense intended.
Jerry B
09-10-2003 04:56:11
 Re: Re: Re: Super M Head Cracks in reply to CNKS, 09-08-2003 18:14:56
Thanks to all who responded, now I have some options and once figured out can move forward !
