Bolting up cylinder head on Farmall A
Gerald
09-08-2003 20:18:25
I have taken the head off of my Farmall A to have the valves ground. In re-attaching it to the block, what torque values should I use? Also, is there a pattern I should follow in bolting it down? Thanks....Gerald
CNKS
09-09-2003 19:25:41
 Re: Bolting up cylinder head on Farmall A in reply to Gerald, 09-08-2003 20:18:25
IH changed the torque values to 80 ft lbs some years ago. They did not update the manuals, far as I know. See tune up info in www.weberstractorworks.com.
gene b
09-09-2003 04:56:46
I use gaskets from CAR QUEST paint them with hi-temp ALUM. Start in center work each way then redo after a good warm-up and have no problems Very important to have threads clean.
Farmer Bob
09-08-2003 20:50:09
Book says 65 ft. lbs. on head bolts.
Sequence is like this: 7 3 1 5 9 * * * * * * * * * * 10 6 2 4 8
Johan
09-09-2003 07:59:36
 Re: Re: Bolting up cylinder head on Farmall A in reply to Farmer Bob , 09-08-2003 20:50:09
Does it not have nine studs?
Farmer Bob
09-09-2003 16:22:20
 Re: Re: Re: Bolting up cylinder head on Farmall A in reply to Johan, 09-09-2003 07:59:36
Well I'll be dipped! I just knew if I threw an extra one in there someone would correct me and I wasn't wrong!!!!! !
Farmer Bob
09-08-2003 21:03:24
Forgot to mention, do not take them to 65lbs all at once. Go through the sequence with your torque wrench set at 45 lbs. Then repeat at 55lbs. and finally at 65lbs.
