Super A drawbar... strike one
Darren in TN
09-08-2003 20:35:26
Does anyone know where I can get a drawbar for a Super A? Got one from a guy today, but it was modified and does not fit my tractor at all. It had the original brackets replaced with new ones that looked good, but are drilled wrong for the mounting bolts. Didn't figure it out till I got home (about a forty minute drive, too).
thanks,
Darren
Bus Driver
09-09-2003 17:50:45
 Re: Super A drawbar... strike one in reply to Darren in TN, 09-08-2003 20:35:26
Had similar problem with drawbar for a (gasp) green tractor. My solution was to borrow the correct part from a friend and to use it as pattern to make what I needed. If not making your own new one, maybe the real thing will show how to modify what you have to something workable.
gregPA
09-09-2003 08:07:30
good morning all, i haven't checked yet today but there was one on ebay yesterday. i see them go pretty frequently there. i'm not sure if it was just a draw bar or swinging draw bar. i go to ebay home page and type in farmall A. just my .02 greg
gregPA
09-09-2003 08:25:33
 Re: Re: Super A drawbar... strike one in reply to gregPA, 09-09-2003 08:07:30
hello, drawbars are still on auction block.
standard drawbar ebay item #2556624654
swinging attachment ebay item #2556936694 greg
gene b
09-09-2003 04:52:05
They are hard to find. If it doesent have to be correct a little work and one off a B will work and be lots stronger like HUGH said a little welding and your in. Knew i should have bought the one at flea market just needed sand blasting.
Darren in TN
09-09-2003 04:59:56
 Re: Re: Super A drawbar... strike one in reply to gene b, 09-09-2003 04:52:05
What flea market was that Gene? (Just kidding... unless it happens to be in my neck of the woods.)
gene b
09-09-2003 16:11:18
 Re: Re: Re: Super A drawbar... strike one in reply to Darren in TN, 09-09-2003 04:59:56
PORTLAND IND a few weeks ago they were burried in a load of stuff a guy had and i could see the price.
Hugh MacKay
09-09-2003 03:08:23
Darren: Is the U of the drawbar the right width for your tractor? You sound as though you may not be able to return that drawbar, or it just may not be worth the drive. It the U is the right one and right width I would check with a fabricator on making a set of mounting brackets. He may even be able to change holes on the brackets you have.
My next thought of course is if that bracket will not fit your tractor it will not fit any other A, SA, 100, 130 or 140. So then you have to wonder if the drawbar was indeed an IH drawbar, unless for a Cub. Cub could be same drawbar with different brackets, not sure on that one.
Those drawbars for Super A could be a bit scarce. I have been told of tobacco growers buying Super A tractors new without a drawbar of any kind, just a bracket similar to drawbar mount, only designed for mounting rear cultivator gangs. If that practice was done in any volume, drawbars could be hard to find.
Darren in TN
09-09-2003 04:58:02
 Re: Re: Super A drawbar... strike one in reply to Hugh MacKay, 09-09-2003 03:08:23
Hugh,
I've heard the same thing about Super A's-- that they were (and are) a favorite among tobacco growers and that they were used principally for cultivating. This drawbar is kind of the right width-- someone welded homemade brackets to it and they are about 1/4" too wide at top, just right at bottom. It doesn't hook over the bolts at two points on each side like original SA drawbars, but rather is set up to be bolted to the the tractor at three points on each side through drilled holes. It looks like an IH drawbar, though I cannot find any markings and cannot match it to any other by photos. The fellow who sold it to me was nice enough and seemed an honest guy, so I'll try to return it to him. You're right about the rarity of these things-- trying to find one has been exasperating.
Thanks again,
Darren
