steering u-joints
Eric
09-09-2003 21:52:01
Has anybody ever replaced the u-joints on the steering rod on a M? Can a new joint still be bought? Any advice welcome, thanks.
Theman
09-10-2003 08:34:18
 Re: steering u-joints in reply to Eric, 09-09-2003 21:52:01
Most likely all you need is the cross for the u-joint. I bought one for my H at the local TSC store. I have no reason to believe the M is any different. Take the forged yoke piece with you to match up the size. It used the same clips that go inside the yokes as the original. The only thing to be careful with during assembly is making sure the grease fitting is on the correct side.
Bob K
09-10-2003 08:06:25
Try Valu-Built catalog. Don't have the # or wesite address (run a search), but I know they have steering u-joints. Good luck.
rustyfarmall
09-10-2003 04:15:12
I think you can still get these from your Case-IH dealer, I also remember seeing them listed in an aftermarket suppliers catalog, but don't remember which one.
gene b
09-10-2003 04:12:56
Replacements are around 45
