Torque values for Farmall A manifold
Gerald
09-11-2003 20:05:49
What should be the torque used to re-install the exhaust / intake manifold on a Farmall A? Also what pattern of bolt tightening should I use? Thanks in advance.....Gerald
Randy in NE
09-12-2003 04:36:06
 Re: Torque values for Farmall A manifold in reply to Gerald, 09-11-2003 20:05:49
I just replaced the head gasket on my '50 C. It has the same 113 cu. in. motor that the A has. The spec sheet calls for 20 ft-lbs. I started at the center and worked out in each direction. My manifold was semi-split into three sections with two studs for each section.
