Hydra-touch control valves
William C. Owen
09-13-2003 14:50:25
I have an I/H 300 that has an hydra touch control valve that does not center when you release the handle. The manual says it is probably the control valve centering spring. it shows a diagram of how to disassemble the valve to get at the spring,but I am a little leary about tearing into that valve. Without any more experiance than I have with these things. are there spare parts available for these valves? just in case I break some part inside of it.or can I buy another valve somewhere?Has anyone come up with another way to get the valve to center without taking it apart? I would appreciate any help,or suggestions. Willy Owens.N.E.Penna.
Redblood
03-08-2009 19:44:19
 Farmall H 1950 My first Resto in reply to
IH fan
12-31-2009 06:26:12
 Re: Checkrow planting and cultivating in reply to LenNH, 12-30-2009 15:45:45
[quote="LA in WI"](quoted from post at 00:59:43 12/31/09) Picture this scene with wire-checked corn:
Just before sunset.
Clear skies.
Slight breeze.
Corn about 6-10" high.
Freshly cultivated.
You are looking from east end of field, with sun glistening off (or thru) the leaves.
You can see all kinds of geometric rows, at many angles.
Beautiful. Just beautiful.
It sure was... although Dad quit check-row planting by the late '40s, I still remember seeing it well into the '50s, at least in NE Iowa. I know Dad never used check-row after going to a mounted planter on the C, I think in 1950, but it had the roll of wire with the planter. When Mom left the farm (mid-'90s) there was a very nice pull type 2 row IH planter left in the barn with the wire and it didn't look like it had ever been un-rolled or the stakes pushed in the ground.
Hugh MacKay
09-13-2003 17:45:57
 Re: Hydra-touch control valves in reply to William C. Owens, 09-13-2003 14:50:25
William: Taking these apart is not a difficult task. Not a nightmare on tiny parts, or anything of the kind. Spring is a possability, could be some wear in places. I don't know if you can still buy new parts. However 300-400 through to end of 460-560 production all used same valve so tractor wreckers should have a supply.
