IH potatoe harvester
kim
09-13-2003 18:24:09
I just bought a very old harvester everything seems to work except the digger blade is broken can I get a new blade or if Iget one made would anyone know the grade of steel.This model has an extra set of sprokets looks like there might have been another coveyer out the back . any info would be very helpfull. thanks
oldiron29
03-07-2009 08:43:46
 Re: F12 front steel wheel in reply to MTC, 03-07-2009 07:06:10
Mike, When you asked last time I thought you has double wheels. You have a single wheel I have never seen one like that. My be very early F-12 1933. There where some preproduction tractors that my have had this wheel. oldiron29
Hugh MacKay
03-07-2009 08:09:26
 Re: water pump 123 engine in reply to thumbanger, 03-07-2009 06:55:06
Thumbanger: Putting kits in C-123 water pumps is one of the poorest paying jobs in the western hemisphere.
If you can figure any way take the kit back and trade your pump for a rebuilt
Larry806
03-07-2009 07:28:27
 Re: Friendly message to Dwight selling the Super C in reply to mkirsch, 03-06-2009 19:42:49
I've advertised the same way . As said below I can get more in parts .
What I call common tractors , Farmall C , H & M 's JD A & B's are hard to make any money on unless I part them . I have a 51 JD A I bought thinking I have the parts it need's . After I got it home I remembered that the parts I
need went in the last scrap roll off we sent out . Now I could offer it for sale needing a few things or I'll cut it . About the best I can do selling it whole is break even . Parting it with 4 hours work I can make money .
MTC
03-07-2009 12:52:19
 Re: F12 front steel wheel in reply to oldiron29, 03-07-2009 08:43:46
third party image
another view from the front.thanks
Marjorie Van Fossen
03-08-2009 17:48:57
 where do I check the rear end oil in my 15-30 in reply to oldiron29, 03-07-2009 08:43:46
Jim J
03-08-2009 10:34:20
 Re: IH 1566 Hydraulic Problem, Lost Hydraulics in reply to cowboyken, 03-07-2009 18:06:23
Check the o-ring on the filter cover before you do any thing else.
