Rear Wheel (Differential?) Fluid
UpHere
09-23-2003 07:05:22
Got a IH624 that is leaking fluid from the rear axle housing. It is only started to do this when I topped up the fluid levels in both rear wheels with Hytran as recommended by my IH dealer. Now I'm wondering if the fluid should be more like 80/90W gear oil - given the age of this beast would heavier oil in there hurt it any?
Hugh MacKay
09-23-2003 17:23:28
 Re: Rear Wheel (Differential?) Fluid in reply to UpHere, 09-23-2003 07:05:22
Your 624 rear differential and transmission oil is also your hydraulic oil so the answer is hy-tran only. You will have to repair those axle seals, or your system will soon be low again.
UpHere
09-24-2003 11:19:02
 Re: Re: Rear Wheel (Differential?) Fluid in reply to Hugh MacKay, 09-23-2003 17:23:28
...I was looking for a quick fix - but the brakes need to be done anyways so I might as well bite the bullet and do it all at once! - thanks.
