Anti-freeze loss on 1940 Farmall A
Dave
09-23-2003 19:00:10
When I pour anti-freeze into my Farmall A, it seems to go straight through and come out at the viewing port which is directly behind the Oil Pan. There does not seem to be any anti-freeze in the oil. Could this be a blown head gasket, or is there more?
Kurow
09-24-2003 17:07:03
 Re: Anti-freeze loss on 1940 Farmall A in reply to Dave, 09-23-2003 19:00:10
It will be the frost plug in the back of the block. It will be rusted out. A fiddly job splitting the tractor. Do both while you are at it.
Stephen
parts man
09-23-2003 20:21:13
Dave, sounds like you mean the access cover to the flywheel? If so, that's probably a cracked block, sorry!! You'll have to split the tractor to find out. If it's cracked they can be welded. First check around under the gas tank and around the outside of everything for signs of the leak. The head is above the clutch housing so if it's the head gasket it will be visible.
mbnok
09-23-2003 20:15:49
There is a soft plug, freeze plug, behind the flywheel it could be the problem. I would like to use a brass plug. If I ever change it again. Haven't had to change it much since using permanet antifreeze. Alcohol was used in the old days, it didn't work in thermo syphon systems. We luckly just pushed out the soft plug, some cracked their blocks.
