F11 Loader vs. Saginaw
PatM
09-23-2003 19:36:38
third party image
Just got my Saginaw 3 pt. Well built, good looking, makes the rusty paint on the tractor look even worse. Daughter says we gotta paint the tractor.
HOWEVER, the darn bracket (3'x3"x1/2" angle) for the loader is flush with the back of the draw bar angle (the side away from the axle), and the vertical angel on the Saginaw needs to extend 1 inch outside the bolts for the loader bracket. Has anyone had this problem. It looks as though I could cut the loader barcket bolts to behind the drawbar/hitch angle and things would work, if the loader bracket was an inch shorter. Has anyone solcved this problem?
Is that the correct Farmhand bracket for a Farmall M? I'm thinking 1"x3"x1" channel, drilled appropriately in pace of the loader bracket angle.
third party image
26Red
09-24-2003 10:34:04
 Re: F11 Loader vs. Saginaw in reply to PatM, 09-23-2003 19:36:38
Maybe you could flip the loader angle brackets around so it has a wider stance. That may give you enough clearance to get around the saginaw unit. Or you could move them in to match up with the saginaw mounting brackets- that would require some fab work though.
Nebraska Cowman
09-24-2003 10:26:06
yes, your loader brackets look just like mine. do what ever you have to to make it work. Maybe use a pair of the square irons like hold the farmall drawbar?
PatM - the pics
09-24-2003 10:04:33
Dang it, they showed up when I posted last night.
Nebraska Cowman
09-24-2003 04:26:11
pat, i have an f11 on am M. can't see your pics
